Adds a filter to a filter profile.
| hex_profile_name | Specifies the filter profile that the current filter is added to. The value is to be supplied as a colon separated string of hex octets. |
| profile_name | Specifies the filter profile that the current filter is added to in ASCII format. |
| object identifier | Specifies a MIB subtree. |
| subtree_mask | Specifies a hex octet string used to mask the subtree. For example, f7a indicates 1.1.1.1.0.1.1.1.1.0.1.0. |
| included | Specifies that the MIB subtree defined by object identifier/mask is to be included. |
| excluded | Specifies that the MIB subtree defined by object identifier/mask is to be excluded. |
| volatile | Specifies volatile storage. |
mask value—empty string (all 1s).
type—included.
storage—non-volatile.
Use this command to create a filter entry in the snmpNotifyFilterTable. Each filter includes or excludes a portion of the MIB. Multiple filter entries comprise a filter profile that can eventually be associated with a target address. Other commands are used to associate a filter profile with a parameter name, and the parameter name with a target address.
This command can be used multiple times to configure the exact filter profile desired.
The following command adds a filter to the filter profile prof1 that includes the MIB subtree 1.3.6.1.4.1/f0:
configure snmpv3 add filter prof1 subtree 1.3.6.1.4.1/f0 type included
The hex_profile_name parameter was added in ExtremeXOS 11.0.
